Macro for deletion of unnecessary tags in an HTML file at current position of text cursor
6
    8:37 - May 02#1
    I would like a macro which deletes tags based at current position of the caret, no matter where is the text cursor:
    • at the beginning of an opening tag;
    • inside an opening tag;
    • between opening and closing tag;
    • at the beginning of a closing tag;
    • inside a closing tag.
    The macro should delete opening and closing tag.
    Here is an example HTML file.
    <html>
    <head>
    <title>EXAMPLE</title>
    </head>
    <body>
    <p class="indent">EXAMPLE FILE</p>
    <p>===Unnecessary tags==</p>
    <p>These are useless tags. Opening and closing tags should be deleted together.</p>
    <p><b>Aaa</b>
    should be just
    Aaa</p>
    <p><i>Bbb</i>
    should be just
    Bbb</p>
    <p><u>Ccc</u>
    should be just
    Ccc</p>
    <p class="indent">Example <a id="rref6" href="#ref6">6</a>
    should be just
    Example 6</p>
    </body>
    </html>
    Here is a macro which I have so far. It works only on the opening tag. If the caret is at opening tag, then the two tags are deleted together.
    PerlReOn
    Find RegExp Up "(?<=<)\w+"
    UltraEditReOn
    Find RegExp "</^c>"
    Key DEL
    UltraEditReOn
    Find RegExp Up "<^c*>"
    Key DEL
      10:26 - May 04#2
      Here is a macro for this task which was quickly developed and poorly tested with UltraEdit for Windows v2024.0.0.28. It can be used for HTML, XHTML and XML files.
      The macro has no HTML / XHTML / XML language knowledge. It does not determine if the text to delete is really an HTML, XHTML or XML tag. It does not analyze the structure to find the matching tag. It just deletes the next closing or opening tag. It does not recognize if there is an opening tag in an HTML file like <li> without the optional end tag </li> for deletion of only the opening tag in this case. It does not determine if the first tag found is an empty tag like <br> or <br />. The user using this macro should know when it is executed and what it really does. There can be of course used the command Undo to undo unwanted deletions.
      UltraEditReOn
      IfCharIs "<"
      Find MatchCase RegExp "[<>]"
      IfNotFound
      Find MatchCase RegExp Up "[<>]"
      IfNotFound
      ExitMacro
      Key LEFT ARROW
      IfCharIs ">"
      Find MatchCase Up "<"
      IfNotFound
      ExitMacro
      Key LEFT ARROW
      Key RIGHT ARROW
      IfCharIs "/"
      Find RegExp "[a-z]+"
      ExitMacro
      Key LEFT ARROW
      Find MatchCase RegExp "</[~>]+>"
      Replace ""
      Find RegExp Up "<^c[^t^n^r >]"
      Key LEFT ARROW
      Key LEFT ARROW
      Find MatchCase RegExp "<[~>]+>"
      Replace ""
      ExitMacro
      Key LEFT ARROW
      Replace ""
      Find RegExp "</^c[^t^n^r ]++>"
      Replace ""
      The code is better understandable with indentations.
      UltraEditReOn
      IfCharIs "<"
          IfNotFound
              IfNotFound
                  ExitMacro
          Key LEFT ARROW
          IfCharIs ">"
              IfNotFound
                  ExitMacro
              Key LEFT ARROW
      Key RIGHT ARROW
      IfCharIs "/"
              ExitMacro
          Key LEFT ARROW
          Replace ""
              Key LEFT ARROW
              Key LEFT ARROW
              Replace ""
              ExitMacro
          Key LEFT ARROW
          Replace ""
          Replace ""
      6
        14:07 - May 04#3
        Thank you
        It works properly
