Split a file and save split parts as file and open them byUE
    Oct 19, 2005#1
    In other words I need to copy from .PROGRAM to .END of each routine and save every split routine in a file (with ".pg" as extension) with the same name of routine (path of file: same of that souce file)
    Immediately after I need to open those file by UE
    1) example of souce file :
    .PROGRAM routine_1()
    ...here is body of this routine
    .END
    .PROGRAM routine_100()
    .END
    2) files generated and opened by UE macro :
    routine_1.pg
    routine_100.pg
      Re: Split a file and save split parts as file and open them
      Oct 19, 2005#2
      Here is what you need. Look into the macro code and try to understand it. Make sure you have the source file open and active before starting the macro.
      CopyFilePath
      NewFile
      Find Up "\"
      Key RIGHT ARROW
      Key LEFT ARROW
      DeleteToEndofLine
      SelectAll
      CloseFile NoSave
      Clipboard 8
      Find ".PROGRAM"
      IfNotFound
      Find Select ".END"
      Key HOME
      NewFile
      Find RegExp ".PROGRAM[ ^t]+"
      Key LEFT ARROW
      Key RIGHT ARROW
      Find Select "("
      Key LEFT ARROW
      Clipboard 8
      ".pg"
      SelectToTop
      Cut
      SaveAs "^c"
      NextWindow
      UnixReOn
      Remove the last red command, if you use regular expression in UltraEdit style by default instead of Unix style - see Advanced - Configuration - Find - Unix style Regular Expressions. UnixReOn/UnixReOff modifies this setting.
        Dec 05, 2005#3
        I was wondering if there was a way to use the Advanced Sorting options to specify a column as a control-break column, and split a file by changes in a key-field.
        That would be an awesome feature/method for breaking data files up.
