wrap selected text, with conditions
8
    Oct 31, 2005#1
    I've tried to do a simple macro :
    wrap the selected text with "<a href="selText">selText</a> if selText begin by "http" or
    wrap the selected text with "<a href="http://selText">selText</a> if not.
    My macro always add "http://".
    Do you see the problem ?
    Find Select "http"
      Cut
      "<a href=""
      "</a>"
      Cut
      "<a href="http://"
      "</a>"
    thanks
      Oct 31, 2005#2
      I think you have misunderstood something. Find Select "http" does not search for "http" in the selected area. It searches for "http" and selects everything from current cursor position to "http" if found (same as holding Shift key while pressing the OK button in the find dialog). It's not possible to search only inside a selected area.
      And I have never tried but I guess, that Find Select with IfFound or IfNotFound is not possible. This combination simply makes no sense.
      Suggestion:
      First always delete "http://" in the selected text and then always add it.
      Find "http://"
      Replace All SelectText ""
      344
        Oct 31, 2005#3
        Either I went stupid or there is a bug in "find select" (10.20+2) ....
        It never finds anything....
        Type this complicated file:
        Hello
        you
        out
        there
        and mark whatevery you want, say, "you"
        Now play the makro that looks for "you":
        Find Select "you"
        "yes !!!"
        "no :-("
        I'm keen on your behaviour on this ...
        P.S. Its not better when working with "StartSelect" ...
        rds bego
        8
          Nov 01, 2005#4
          thank you Mofi,
          It's working well now.
          I've had a "clipboard 8 copy" to keep the original string.
          Here is the new one :
          Clipboard 8
          Find "http://"
          Cut
          "<a href="http://"
          Clipboard 8
          "</a>"
          Bego :
          mofi wrote:I guess, that Find Select with IfFound or IfNotFound is not possible.
          344
            Nov 01, 2005#5
            Hi neekolo & Mofi,
            seems so. Nevertheless, help file isn't helpful here: :?
            Find Select: Nur markierten Text durchsuchen (optional).
            (Only find in marked text)
            Anyway there is a good solution for that now ... :wink:
            rds Bego
              Nov 01, 2005#6
              Bego wrote:Find Select: Nur markierten Text durchsuchen (optional).
              In English help the option Select is described as follows:
              Select - indicates the text should be selected from the current selection/position to the end of the search target
              If this is wrong described in German help, you should report this to IDM.
              To test if Find Select has found something, use IfSel command instead of IfFound.
