Find and replace function names
    Nov 20, 2005#1
    How can I replace this with a regular expression.
    "public int __ReplaceTheFirstLetter" or
    "public string __ReplaceTheFirstLetter"
    to
    "private int replaceTheFirstLetter"
    "private string replaceTheFirstLetter"
    I want to get rid of the double underscores and convert public to private and replace the first Cap. letter after the underscores to lowercase.
    6,683583
      Nov 20, 2005#2
      It's not possible to lower not specified characters with a replace command. But this macro will do it.
      Important: Macro property option Continue if a Find with Replace not found must be enabled.
      Find MatchCase RegExp "public +[a-z]+ +_+[A-Z]"
      ToLower
      Find MatchCase RegExp "public +^([a-z]+^) +_+^([a-z]^)"
      Replace All "private ^1 ^2"
      UnixReOn
