Hierarchy replace
Hierarchy replace
    Jan 09, 2006#1
    I have a text file that has an embedded hierachy
    Table: table1
    Column1
    Column2
    Table: table2
    Column1
    Column2
    I want to get to
    table1 column1
    table1 column2
    table2 column1
    table2 column2
      Jan 09, 2006#2
      This macro modifies the example you post like you want:
      Bottom
      "Table:
      Find RegExp "%Table: "
      Delete
      Key END
      Cut
      Key DEL
      Find RegExp Select "%Table: "
      IfSel
      Key UP ARROW
      Key END
      Find RegExp "%"
      Replace All SelectText "^c "
      Key DOWN ARROW
      Key HOME
      UnixReOn
      And don't forget to enable the macro property Continue if a Find with Replace not found.
