Macro that indents lines as the line before
344
    Jan 24, 2006#1
    Hi guys,
    Here is a macro that indents lines exactly the same as the line before and automatically jumps down one line.
    It is quite good if you have flattered-structures like this:
    if i < 1 then
       only2Spacesbefore = 3
     	 tabAndSpacesBeforeMe = 2
    	Just a tab before me !
    		2 tabs before me :-(
    end if
    to end 'em up like that:
    if i < 1 then
    end if
    Bind the macro to a key, e.g. alt-^
    Format the 1st line in the block as you like it (here: 3 spaces)
    Goto to the second line of the block and press alt-^ 3 times.
    You see that all lines in the block are indented with 3 spaces :-)
    One limit: It does NOT work correctly if the line before starts at column 1.
    (Maybe s.o. has a solution without a 2nd macro because of loop-nesting-problem)
    Maybe you like it, otherwise, ignore it.
    Improvements and comments are welcome.
    rds Bego :wink:
    UnixReOn
    Key UP ARROW
    Key END
    IfColNumGt 1
    PlayMacro 1 "KEY_HOME"
    Find RegExp "\S"
    Key LEFT ARROW
    Key DOWN ARROW
    Key END
    IfColNumGt 1
    Find RegExp "\S"
    Key LEFT ARROW
    Key DOWN ARROW
    The Macro KEY_HOME looks like this and ensures that - whatever settings in UE you set - the cursor surely is at the beginning of the line.
    A Key Home is enough, if your setting "always position Key Home at col 1" is set.
    Key HOME
    IfColNumGt 1
    Key HOME
      Jan 24, 2006#2
      Hello Bego!
      You wanted an improved version, here it is. It has no problems with column 1 (previous line can be also an empty line) and it should also work for all files indepedent of the line termination (DOS/Unix/MAC). It uses a complete different method without clipboard usage.
      The macro with an UltraEdit style regular expression:
      Key UP ARROW
      Key HOME
      IfColNumGt 1
      Key HOME
      Find RegExp "%^([ ^t]++^)^([~^r^n]++[^r^n]+^)[ ^t]++"
      Replace "^1^2^1"
      The same macro but with an Unix style regular expression:
      UnixReOn
      Key UP ARROW
      Key HOME
      IfColNumGt 1
      Key HOME
      Find RegExp "^(\s*)([^\r\n]*[\r\n]+)\s*"
      Replace "\1\2\1"
      344
        Jan 24, 2006#3
        Hi Mofi !!! :-)
        What shall I say. The chief-supporter himself made it once again.
        I took your solution .... I think it's just a BIT more clever ;-)
        Amazing what regexp's are good for .... :o
        rds Bego
