How to insert the line number into the actual text file?
5
    Feb 04, 2006#1
    UE can show line number, but I want to insert the line number at the beginning of each line? how to do it?
    206
      Feb 04, 2006#2
      Position the cursor at the top of the file.
      Turn on Column Mode
      menu:
      Column > Insert Number First Number 1, Increment 1
      You could also use Column > Insert/Fill first to put one or more spaces at the start of each line before the line numbers - or a regex Search/Replace would do the same thing.
      Software For Metalworking
