Hello
I have a problem is that I have to do a large file containing binary data wich should be converted into hex data.
Example of a conversion result
into00110111 10101000 00000111
00110111 10100000 00011111
I tried to use the number converter. I can't call the tool (isn't recorded by a quick macro) or do a search and replace in a rang from 0- 2550x37A807
0x37A01F
