The UltraEdit macro language does not support variables. So you can't use GotoLine with a variable line number loaded from a different file. You can specify the line number on the command line of uedit32.exe when opening a file - see in help of UltraEdit the topic "Command Line Parameters". Maybe this will help you.
If you want to solve your problem with a macro, you have to temporary edit file#2 to go to the line you want. Here is the macro which goes to the line which number (as string) is currently in the clipboard. You can develop the part to copy the line number from file#1 to clipboard by yourself.
How it works:
It inserts at every line with the insert number feature of the column mode the line number and a separator string. Then it goes to the line specified in the current clipboard, modifies the inserted separator string of this line, removes all line numbers and the separator string and goes again to the special marked line where it deletes the mark. Awful, but it works. You can use a different separator string than #!##! and a different special mark string than !#!!# if you don't like these strings or the could exist in your file#2.
Don't forget to enable the macro property Continue if a Find with Replace not found.
ColumnModeOn
SelectToBottom
Key HOME
ColumnInsertNum 1 1 LeadingZero
Find "^c#!##!"
Find RegExp "%[0-9]+#!##!"
Replace All ""
Find "!#!!#"
Delete
EndIf UnixReOn
