Insert from separate file
    Mar 17, 2006#1
    I have two files with strings on separated lines, and I want to insert the strings from one file into a regular place in the corresponding lines in the second file.
    File 1, line 1: <string in File1>
    File 2, line 1: stringInFile2
    Desired output: <string in stringInFile2 File1>
    File replace works for unique strings, but I dont understand 1) how to use variable strings and 2) how to do this between two files.
    Any help?
    Thanks in advance.
      Mar 17, 2006#2
      I have understand you right this is definitively a job for a macro. Simply record one manually executed line merge with cursor position to next line and then run the macro until end of file.
        Mar 17, 2006#3
        Thanks Mofi - but these are two different files, with different elements on each line. The only constant are the element terms:
        File 1..........................File 2
        <element foo="1s"> | data="4v"
        <element foo="2r"> | data="5g"
        <element data="4v" foo="1s">
        <element data="5g" foo="2r">
        Hope this is a little clearer.
          Mar 18, 2006#4
          The following macro will do what your example shows. Don't forget to enable the macro property Continue if a Find with Replace not found. Have only the 2 files open when running the macro and file 1 must have the focus.
          Bottom
          IfColNum 1
          NextWindow
          Bottom
          IfColNum 1
          TrimTrailingSpaces
          IfEof
          Key END
          Key HOME
          IfColNumGt 1
          Key HOME
          Key DOWN ARROW
          PreviousWindow
          Find MatchCase "<element"
          IfNotFound
          Key RIGHT ARROW
          Key HOME
          IfColNumGt 1
          Key HOME
          Key DOWN ARROW
          IfEof
          NextWindow
