I need to use the ColumnInsert command in my macro. This command has one argument - the text I would like to replace. If I run Insert/Fill Columns from the menu, a dialog is shown. There I can enter the value I would like to be inserted to the column.
Is there any way I can tell the macrocommand to show the dialog and ask me for the value like if I use the menu for the same funktionality?
