Two problems here, really.
I am starting Uedit 12.10+3 from the command line with two files to open and a simple macro to run. Its purpose is to read the (very short) files looking for the string 'ERROR During" at the start of any line, and to run a Tool if found.
The command line is:
According to the Help, the "/M,E" syntax should run the macro and exit Uedit at the end. Uedit does not close, however. "Minimize on last file close" is NOT checked.
The problem with the macro is that the Tool is run twice, even though the ERROR string only occurs in one of the files. The macro is:
Loop 2
Find MatchCase "^PERROR During"
RunTool "Entity Chart"
CloseFile
Any ideas?
TIA,
Alan
start uedit32.exe "C:\Bck_Log.log" "C:\Bck_Data.log" /M,E,1="C:\Logs.MAC"
Loop 2
CloseFile
Any ideas?
TIA,
Alan
