Find and replace data in a specific text field
    Aug 10, 2006#1
    Hi New to this macro game, hope someone can help plz.
    I have a text file with around 5000 lines. I will use the example below to explain what I am upto....
    I am trying to find lines starting with AA then to look at column 50 and replace the 01 with 00
    Before
    AA 01
    AB 01
    After
    AA 00
    AB 00
    Any ideas?
    Thank-you
    Hunt
      Aug 11, 2006#2
      I don't understand your example. Is only column 50 (or 51) of the line starting with AA set to 0 or also all following lines because AB line has also changed to 00.
      If only 01 in the line starting with AA must be set to 00, it can be done without a macro with following UltraEdit style regular expression replace:
      Find: %^(AA???????????????????????????????????????????????^)01
      Replace: ^100
        Aug 11, 2006#3
        Hi thanks for the reply, sry the first example it was not great...
        I am looking for multiple strings.
        I wish to change for example the 01s when AA or AB is found at the start of the line. In reality I am going to be looking for about 50 combinations, so i believe a macro with a loop would help(problem is I dont have the skills to write one :cry: ).
        Before
        AA 01
        AA 01
        AA 01
        AA 01
        AB 01
        AB 01
        AB 01
        After
        AA 00
        AA 00
        AA 00
        AA 00
        AB 00
        AB 00
        AB 00
        Not sure what the ultra edit style is either........... omg
        Many thanks for your help
        8O
          Aug 11, 2006#4
          See Advanced - Configuration - Search - Regular Expression Engine which engine/style you use for regular expression searches and replaces.
          The following macro solution needs the macro property Continue if a Find with Replace not found checked.
          You can read in my second post at multiple files conversions help how to create a new macro and paste the following code into it.
          Find MatchCase RegExp "%^(AA???????????????????????????????????????????????^)01"
          Replace All "^100"
          Find MatchCase RegExp "%^(AB???????????????????????????????????????????????^)01"
          Replace All "^100"
          ... and so on for all your combinations
          Well, the 2 regex above could be also combined to a single one:
          Find MatchCase RegExp "%^(A[AB]???????????????????????????????????????????????^)01"
          Replace All "^100"
          See help of UltraEdit about the Find command and the Regular expressions to understand these regular expressions.
            Aug 12, 2006#5
            Thank you....
            Worked a treat :P
            Excellent Work
