Quick macro prob. data file query via macro.
    Sep 18, 2006#1
    I have been looking for these on msg boards, and am finding things more elaborate then what I need. Sorry to repeat post on the subjects...
    I have a 12 meg text file. I want to use it as reference for a macro driven lookup, or aka a huge index file. I want to open this text file, run a macro, utilize GetValue, ask the question "Search Term?" and then go start from the bottom and work its way up. I prefer Reg Expression. Now, once it finds the phrase of data, I would prefer a line copy, I would also like to use that list option to display where it shows other references in the entire doc. That is so cool. All info is much appreciated, I love this program, never have time to play with it.
    Here, I will give you a laugh.. I am probably way off.. but
    Bottom
    Key Ctrl+END
    GetValue "Search Term?"
    <I type some search term>
    Find RegExp Up "%1 " <whatever the equivalent is in UltraEdit>
    IfFound hightlight
    <end macro>
    ThankYou!
      Sep 18, 2006#2
      I don't know why you need a macro for this job, but however, here is it. The macro property Continue if a Find with Replace not found must be checked for this macro.
      Please note:
      1) A regular expression search with a variable string - here with the string you entered copied to user clipboard 9 - is only possible with the UltraEdit regular expression engine. It's not possible with the legacy Unix or the Perl engine. So the macro uses the command UnixReOff to switch to the UltraEdit engine and you must enter the regex search string with UltraEdit syntax.
      2) A regular expression search upwards often fails where it finds the string downwards. Maybe it would be better to first search from top of the file down and copy the line where it was found last if at least found once - see macro solution 2.
      3) To highlight all occurences of the string in the whole file like with the find option Highlight All Items Found is not possible from within a macro. You can see this easily if you record a find with this option checked and look at the recorded macro code. You will not see a single Find command with an appropriate parameter, you will see as many find commands as needed to find all occurences of the searched string in the file from current cursor position.
      Solution 1 with regular expression find upwards:
      Bottom
      IfColNum 1
      GetString "Search Term?"
      Key HOME
      Key HOME
      Cut
      Find RegExp Up "^c"
      SelectLine
      Key UP ARROW
      Find RegExp "^c"
      Solution 2 with regular expression find downwards and only the line with the last occurence is copied to the windows clipboard:
      Bottom
      IfColNum 1
      Key HOME
      Key HOME
      Cut
      Find RegExp "^c"
      Find RegExp "^c"
      IfNotFound
      SelectLine
      Key UP ARROW
      Find RegExp "^c"
