Find records containing part of another tab
10
    Oct 19, 2006#1
    Well, that was hard to find a topic title which describes what I mean...and it is so simple.... 8O :wink:
    I've got two tabs open:
    edit 1 = 25000 records of text with some id's
    edit 2 = 10 records containing only a fewid's (each line is one id)
    Is it possible to select ("list lines containing string") in one go only those lines of "Edit 1" containing the id's that are present in tab "Edit 2".
    Now I do 10 find-commands, but can this be done easier???
    Thanks in advance,
    Michael
      Oct 20, 2006#2
      With UE v12.00+ and the Perl regular expression engine and simple IDs you can run a single regular expression find with the 10 IDs in an OR expression like (ID1|ID2|ID3|ID4|ID5|ID6|ID7|ID8|ID3|ID10).
      Or you use the following macro which is designed to find all strings from file 2 which contains 1 search string per line and collects the lines found with those strings in the windows clipboard. The macro is similar to the macro posted at equivalent to egrep ??(extract line from big files).
      You should have only the 2 files opened and file 2 must have the focus when you start the macro.
      Disadvantage of this macro in comparison with a single Perl regular expression search: the lines are sorted by the search strings and duplicate lines are possible. But that can be also an advantage.
      The macro temporarily modifies file 1. So it's not possible to have file 1 open in read-only mode. Well, the macro could be rewritten to not modify file 1 and use window/document switches. But this would slow down macro execution a lot.
      After executing the macro the windows clipboard contains the lines with any of the search string from the list in file 2. Duplicate lines are possible if a line contains more than 1 search string from the list in file 2.
      Bottom
      IfColNum 1
      Find "^p^p"
      Replace All "^p"
      IfNotFound
      SelectAll
      NextDocument
      Bottom
      IfColNum 1
      Key END
      Cut
      Key DEL
      Find "^c"
      SelectLine
      CopyAppend
      IfCharIs "»"
      DeleteLine
      Key END
      Cut
      Key DEL
