Adding Quotes on Selective Lines
    Nov 08, 2006#1
    I have a series of lines, names and address type stuff that came out in a funky format. To now import them into another system I need to put quotes (" ") around all the lines EXCEPT first and last line in a series.
    Each series is separated by 1 or 2 blank lines
    I am using the latest UltraEdit 12.20a+2 and could not figure out a viable regular expression yet based on what I have seen it seems like there should be one with the new Perl compatible engine.
    thanks for any help and ideas
    Alan
    Sample:
    sdfsa, bas,fsdf,adf,adsfafds,asdf,
    ddflk,asd,df
    sadfasdf,sadf,sdf
    sadsadf,adfs,adsf
    df adsf,sadf,asdf,sadf,sadf,
    32 das fadf,adf
    sa,df sadf
    asdd fad fasdfasdfasdf,asd
    23324 dsaf
    3232,adfs,sadf,dsd
    233223,4sd,asdf,sad
    2323sd,dsf ,,dsfadfasdfsadf
    ddflk,asd,df
    sadfasdf,sadf,sdf
    sadsadf,adfs,adsf
    32 das fadf,adf
    sa,df sadf
    23324 dsaf
    3232,adfs,sadf,dsd
    233223,4sd,asdf,sad
    Turn the above into:
    "ddflk,asd,df"
    "sadfasdf,sadf,sdf"
    sadsadf,adfs,adsf
    "32 das fadf,adf"
    sa,df sadf
    "23324 dsaf"
    "3232,adfs,sadf,dsd"
    "233223,4sd,asdf,sad"
    6,676585
      Nov 09, 2006#2
      Very good, you have posted your UltraEdit version and a before and after example. So it was no problem for me to write a macro for this job:
      Bottom
      IfColNum 1
      TrimTrailingSpaces
      Find RegExp "%^([~^p]*^)$"
      Replace All ""^1""
      Find RegExp "^p^p"^(*^)"$"
      Replace All "^p^p^1"
      Find RegExp "%"^([~"]+^)"^p^p"
      Replace All "^1^p^p"
      Bottom
      DeleteLine
      DeleteLine
      DeleteLine
