Re-select pasted text?
6
    Nov 09, 2006#1
    I'd like to create a macro to move a selected text with the keyboard. Therefore in my macro, I would cut a selected text, move the cursor one step in the desired direction and then paste the text. Ok so far.
    But to do this repeatedly, the macro must re-select the pasted text. How could I do that? I think it is not possible to count the number of characters in the clipboard or of the selection?
    TIA,
    Rob
    344
      Nov 09, 2006#2
      Hi Rob,
      reselection and undo are not possible via macro.
      But why don't you just use cut & paste as normal ?
      Where is the benefit ?
      Well, for a SINGLE line, it IS possible.
      Best, bind those 2 move-macros to shift-ctrl-ArrowUp / shift-ctrl-ArrowDown :-)
      rds Bego
      Makro setDefaults (use YOUR favorite default settings for it...)
      UnixReOn
      Makro MoveLineUp:
      IfSel
      SelectLine
      Cut
      Key DOWN ARROW
      Key UP ARROW
      PlayMacro 1 "setDefaults"
      Makro MoveLineDown:
      IfSel
      SelectLine
      Cut
      Key DOWN ARROW
      Key UP ARROW
        Nov 09, 2006#3
        Why do you want to select the pasted text again?
        The text is still in the clipboard after paste and can be pasted as often as you want without selecting it again.
        However, you can select it again by search for the clipboard content:
        Find Up "^c"
        This works for clipboard content with a maximum of 30,000 characters (since v9.20).
        344
          Nov 09, 2006#4
          Tag Mofi,
          I THINK he wants to "VISUALLY move" some lines up or down.
          6
            Nov 10, 2006#5
            Hi Bego, hi Mofi!
            Yep, Bego, you're right, I want to visually move text lines. Since I discovered this feature in Eclipse, I'm eager to have it in UE also. The next logical step was of course to be able to move portions of text to the left and right also.
            BIG thanks Mofi for that great tip using "Find" - it does a great job!
            Bego, thanks for your scripts! I had done the same in the beginning, then I've found the "SelectLine" command, making things a bit easier. A great idea is to have a macro with default settings to restore them after a macro - I will incorporate that in all future macros.
            These are my VisualMove (tm) macros right now:
            Move sel left
            Clipboard 8
            Cut
            Key LEFT ARROW
            Find Up "^c"
            Move sel right
            Clipboard 8
            Cut
            Key RIGHT ARROW
            Find Up "^c"
            Move line down
            Clipboard 8
            SelectLine
            Cut
            Key DOWN ARROW
            Key UP ARROW
            Move line up
            Clipboard 8
            SelectLine
            Cut
            Key UP ARROW
            Key UP ARROW
            Copy line down
            DupeLine
            Copy line up
            DupeLine
            Key UP ARROW
