Grep: Search files in directory for string and log filenames to file
    Nov 09, 2006#1
    Hi I'm trying to search a directory for files containing a specific string and log the path and filename that contain the search string to a new file. I'm trying to mimic the grep command in unix. Hope someone can help me.
    Thanks Val
    6,687587
      Nov 09, 2006#2
      This thread is maybe helpful for you: equivalent to egrep ?? (extract line from big files)
      And here is a macro which uses FindInFiles to create a list of files in which the search string is found.
      It contains some extra code which are workarounds for known problems with Find In Files usage in a macro and should work for v10.20 and higher (tested with v11.20a and v12.20a+1). Since v12.00 the search result is a Unicode file which is detected by this macro and converted to an ASCII file to avoid some problems with Unicode files.
      Adapt the optional and required parameters of command FindInFiles to your need.
      FindInFiles Recursive "Initial directory\" "file specification" "search string"
      Find RegExp Up "%Search complete, found"
      IfNotFound
      NextWindow
      DeleteLine
      HexOn
      Find "00"
      UnicodeToASCII
      Find "----------------------------------------^p"
      Replace All ""
      Find RegExp "%Find '*^p"
      Replace All ""
      Find RegExp "%Found '*^p"
      Replace All ""
      Find RegExp "/[0-9]+:*$"
      Replace All ""
      SortAsc IgnoreCase RemoveDup 1 -1 0 0 0 0 0 0
      344
        Nov 09, 2006#3
        Simply use "Find in Files" in the search menu. (I think it is F4 by default.)
        rds Bego
