Macro to convert to ANSI
    Nov 10, 2006#1
    I am trying to create a macro that converts files to ANSI/ASCII from UniCode. Unfortunately, sometimes the files are already in ANSI/ASCII format and the convert from Unicode to ASCII command ruins the file.
    Is there a way to test the format of the file so I can decide what conversion to use? :?
      Nov 10, 2006#2
      I think I came up with something. 8) The unicode files I am trying to convert have the following 2 bytes in the header "ÿþ" or "FF FE". So I am looking for those bytes in hex mode and converting if they exist. But I am getting an error on my macro (see below). :cry:
      HexOn
      Find "FF FE"
      UnicodeToASCII
      Save
      CloseFile
      344
        Nov 10, 2006#3
        What is the error ?
        If you have an unsaved "new file", save will just quit in an IO-error.
        The makro "works" with previous saved files, either I can't say if unicode-transform works.
        6,687587
          Nov 10, 2006#4
          The conversion to ASCII should not be done in hex edit mode.
          HexOn
          Find "FF FE"
          UnicodeToASCII
          IfNameIs ""
          SaveAs ""
          Save
          CloseFile
