Select and Copy to Multiple Lines
    Nov 10, 2006#1
    I have a file that contains multiple records ending with the text "START". I am looking for a way to perform a conditional select and paste if the line or lines below contain a 4-digit year at the end of the record. All fields are fixd length.
    Data Before:
    Afield1 Afield2 Afield3 START
    2005
    2006
    Bfield1 Bfield2 Bfield3 START
    2003
    2004
    2005
    2006
    Data After:
    Afield1 Afield2 Afield3 2005
    Afield1 Afield2 Afield3 2006
    Bfield1 Bfield2 Bfield3 2003
    Bfield1 Bfield2 Bfield3 2004
    Bfield1 Bfield2 Bfield3 2005
    Bfield1 Bfield2 Bfield3 2006
    I would appreciate any help in writing a macro to perform this function.
    Thanks...
    6,687587
      Nov 10, 2006#2
      Here is the macro which should do the job. It works with UE v11.20a for an ASCII file with DOS line terminations and configuration option Home Key Always Goto Column 1 checked (important if there are START lines with leading spaces/tabs).
      Bottom
      IfColNum 1
      TrimTrailingSpaces
      Find MatchCase RegExp "START$"
      IfNotFound
      Key Ctrl+LEFT ARROW
      Key HOME
      Key DOWN ARROW
      Find MatchCase RegExp Select "START$"
      IfSel
      Key HOME
      SelectToBottom
      Find RegExp "%^([0-9]+^)$"
      Replace All SelectText "^c^1"
