append literal string to clipboard
11
    Jan 31, 2007#1
    hi UE peops ---
    simple macro question that I can't quite finger out. Should be easy, but damn Ive been on it for over 2 hours.
    How do you send a literal string to the clipboard without first copying it or selecting it?
    IOW, I want to send the "," to the clipboard between copyappend operations to separate a csv list.
    a command like ---> ClipboardAppend "," <--- would work if such a command existed. 8)
    anyone know or have a snippet they could share? I know im gonna kick myself when I see how easy it is.
    WZ
      Jan 31, 2007#2
      Exactly the same problem I have also often when I create a list directly in the clipboard with CopyAppend. Unfortunately there is no command to directly copy or append a string to current clipboard. The commands Copy or CopyAppend with an optional string would be really helpful in such situations.
      Currently (UE V12.20b+1) you must insert the comma without deleting something, reselect it and cut & append it.
      your code
      Key LEFT ARROW
      Key RIGHT ARROW
      Key LEFT ARROW
      CutAppend
      11
        Jan 31, 2007#3
        Thanks, Mofi.
        I eventually ended up doing something similar. (I just added my "," writeline in the space after the copied word and selected them both, but yours is a bit cleaner)
        Being anal retentive, :lol:, I was just hoping there was a one liner that would be available instead of using 10.
        Thanks for all your help --- and thanks for being such a prolific poster. You saved me quite a bit of work with your hints and tips, as I read through your regex and macro forum responses.
        tnx mate,
        Wz
