Insert new line before line 1
17
    Jul 12, 2007#1
    I have a "simple" task: I want to insert a new line before line 1 via a macro, but the new line is always entered after line 1.
    Here is what I got:
    Key HOME
    InsertLine
    What is wrong with that?
    262
      Jul 12, 2007#2
      Yes, InsertLine is supposed to act this way as it also says in the help "Inserts blank line below current cursor position". The Edit-menu equivalent "Insert Line" does exactly the same.
      What you need to get what you want is:
        Jul 12, 2007#3
        Thanks a lot. That works.
