round function
round function
6
    Sep 20, 2007#1
    Hello, I'm having numbers and want them to be cut (and round) in the following way
    1 > 1 (or 1.0)
    1.2 > 1.2
    1.23 > 1.2
    1.25 > 1.3
    1.267 > 1.3
    as you see, the numbers can have a different amount of post-comma digits
    how to realize that with a Macro?
      Sep 20, 2007#2
      Nearly impossible with a macro. Rounding down is not a problem. Rounding up is horrible for a number like 9999999.98 > 10000000.0
      I suggest to do that with 2 macros. The first one finds the numbers with at least 2 digits and round it down which is pretty easy. The second one is called by the first one when a round up is required.
      Macro "Find Numbers"
      Find RegExp "[0-9]+.[0-9][0-9]"
      Key LEFT ARROW
      IfCharIs "01234"
      Find RegExp "[0-9]+"
      Replace ""
      Replace ""
      PlayMacro 1 "RoundUp"
      The second macro is a variant of my universal "CountUp" macro posted at counter ? It ignores the decimal point when moving the cursor left and evaluating the character.
      Macro "RoundUp"
      Key LEFT ARROW
      Key LEFT ARROW
      OverStrikeMode
      IfCharIs "0"
      "1"
      IfCharIs "1"
      "2"
      IfCharIs "2"
      "3"
      IfCharIs "3"
      "4"
      IfCharIs "4"
      "5"
      IfCharIs "5"
      "6"
      IfCharIs "6"
      "7"
      IfCharIs "7"
      "8"
      IfCharIs "8"
      "9"
      IfCharIs "9"
      "0"
      Key LEFT ARROW
      IfColNum 1
      "1"
      Key LEFT ARROW
      IfCharIs "."
      Key LEFT ARROW
      IfCharIs "0123456789"
      Key RIGHT ARROW
      "1"
      Find "|"
      Replace ""
      The macro property Continue if a Find with Replace not found or Continue if search string not found should be checked for both macros.
      Add UnixReOn or PerlReOn (v12+ of UE) at the end of the first macro if you do not use UltraEdit style regular expressions by default - see search configuration. Macro command UnixReOff sets the regular expression option to UltraEdit style.
      Important: You have to create first the macro "RoundUp"! The macro name is case-sensitive in the PlayMacro command and the macro must already exist!
