Adding unique client id to over 950,000 names Help!
    Oct 30, 2007#1
    I'm new to this so I need help from those that know what they are talking about. I need to add a field to my mailing list database with a unique client id for each line. I could input it manually but you see the problem as there are over 950,000 names and the lists will only get bigger. I want it to start with a letter and a random number after. doesn't have to be very long but they all have to be different. Thanks.
    236
      Oct 30, 2007#2
      I guess you could do something like that with a script. But I'd also suppose that this script would have serious performance issues since it must check each new random number against all previously used ones.
      The fastest way, I think, would be to use a hash function (as long as the 950.000 lines themselves are all different). I haven't checked, but probably UE's script engine doesn't provide one of those. In Python, the whole thing could be done in three lines:
      output=open("output.csv","w")
      for line in open("input.csv","r"):
         output.write(hex(hash(line)+2147483648)[2:].rstrip("L")+","+line)
      (doesn't necessarily start with a letter, though. Which one would you like?)
      Just as an idea...
      Tim
        Oct 30, 2007#3
        Thanks for the input I wanted to start with A i guess. Start from the beginning is best.
        262
          Oct 30, 2007#4
          I agree that a script could do it but with slow performance.
          As I read it it's not vital that the client id is random as long as it is unique. So I think a fast solution could use a combination of search/replace with regular expression and Mofis CountUp Macro.
          But before going any further we need to see some example lines of your database file. Please supply a before example as well as an after example. Of course you should anonymize sensitive data, but please don't make the examples too generic as they might not resemble real live data close enough.
          Post both examples and surround them with the [­code][/code] tags
            Oct 30, 2007#5
            It's just a simple .txt file with comma delimiters
            STEPHEN,XXXX,XXX WEST XX STREET,NEW YORK,NY,10001,YEAR,MAKE,MODEL,VIN
            LAURA,XXXXX,1XX JANNEY LN,SPRINGBORO,OH,45066,YEAR,MAKE,MODEL,VIN
            JAMES,XXXX,PO BOX XXXX,ARCHER CITY,TX,76351-1224,YEAR,MAKE,MODEL,VIN
            SUSAN M,XXXXX,4XX N Sagehorn Dr,Hartford,SD,57033-2360,YEAR,MAKE,MODEL,VIN
            262
              Oct 31, 2007#6
              On second thought I think I will suggest a different approach. This macro uses the powerful column mode to insert a letter "C" and a number increased by 1 for every line. Give it a go and see if that works for you.
              ColumnModeOn
              SelectToBottom
              SelectToBottom
              "C"
              ColumnInsertNum 1 1 LeadingZero
              Your example will look like this after the macro is run:
              C1,STEPHEN,XXXX,XXX WEST XX STREET,NEW YORK,NY,10001,YEAR,MAKE,MODEL,VIN
              C2,LAURA,XXXXX,1XX JANNEY LN,SPRINGBORO,OH,45066,YEAR,MAKE,MODEL,VIN
              C3,JAMES,XXXX,PO BOX XXXX,ARCHER CITY,TX,76351-1224,YEAR,MAKE,MODEL,VIN
              C4,SUSAN M,XXXXX,4XX N Sagehorn Dr,Hartford,SD,57033-2360,YEAR,MAKE,MODEL,VIN
              6,676579
                Nov 01, 2007#7
                Macro from jorrasdk is a good idea. Here is it again a little bit optimized and with additional code to make sure that "Cxx," is not inserted on empty lines at end of the file.
                Bottom
                IfColNum 1
                Key BACKSPACE
                ColumnModeOn
                ColumnInsert "C,"
                Key RIGHT ARROW
                Bottom
                InsertLine
                  Nov 11, 2007#8
                  You have no idea how much you guys helped me out..........Thank YOU!!
