Replace in all files - HEX mode
9
    Jan 08, 2008#1
    Time to give something back.
    I saw some posts a while ago asking about this so here is my solution
    I have had a need for a while to be able to run a macro on all files but in hex mode as i needed to replace with "00" which has no ascii character.
    I have finally come up with this macro.
    Notes:
    1. all files needing to be edited must be in the same location
    2. all need the same extension. I've used *.txt but edit the macro to suit your own needs
    Open "D:\Data\*.txt"
    HexOn
    Find Select "01"
    Replace All "00"
    Find Select "0c"
    Replace All "00"
    Find Select "03"
    Replace All "00"
    Find Select "02"
    Replace All "00"
    Find Select "05"
    Replace All "00"
    Find Select "1d"
    Replace All "00"
    Find Select "1c"
    Replace All "00"
    Find Select "18"
    Replace All "00"
    Find Select "10"
    Replace All "00"
    Find Select "2a"
    Replace All "00"
    NextDocument
    A few commands maybe out of order but it works for me.
    The NextDocument command simply makes the next tab active.
    Not an elegant solution but seems to work.
    6,672580
      Jan 08, 2008#2
      What about this version?
      HexOn
      IfNameIs ""
      HexOn
      Find "01"
      Replace All "00"
      Find "0c"
      Replace All "00"
      Find "03"
      Replace All "00"
      Find "02"
      Replace All "00"
      Find "05"
      Replace All "00"
      Find "1d"
      Replace All "00"
      Find "1c"
      Replace All "00"
      Find "18"
      Replace All "00"
      Find "10"
      Replace All "00"
      Find "2a"
      Replace All "00"
      CloseFile Save
      NextDocument /*! Must be deleted when using the red code lines. !*/
      It is a known (for IDM and me) bug of the macro recorder that a find/replace in hex edit mode is always recorded with option Select although this option is not needed.
      And you should mention that macro property Continue if a Find with Replace not found or Continue if search string not found must be UNCHECKED for this macro to exit the endless loop if in any file one of the found binary values is not found.
      With the red code lines I have added and with macro property Continue if a Find with Replace not found or Continue if search string not found CHECKED the macro will run all replaces in all files until all files are saved and closed.
      9
        Jan 09, 2008#3
        Thanks Mofi,
        yes yours is a much more elegant way of exiting the macro.
        so basically your version just checks to see if the file name is Null and if so exits.
        cheers
