Check Whether File is Read Only using Macros
9
    Jun 18, 2008#1
    Dear All,
    I need to check whether the file is Read Only or not using macros and send the message accordingly.
    Is that possible using macros?
    Thanks in advance!!
      Jun 18, 2008#2
      This small code tries to insert a character and if that works, the file is not read-only.
      Key HOME
      IfColNumGt 1
      Key HOME
      IfColNum 2
      Key BACKSPACE
      // Insert here the commands for a read-only file.
      A solution without temporary modifying the file is not possible directly. You would need a user tool which checks the file attributes of the current file and reports it back to UltraEdit. That user tool could be executed from within a macro. But maybe this solution is already enough.
