Search and Replace then add lines
    Aug 02, 2004#1
    I would like to create a macro that reads a two digit field in a particular column then insert lines after that count. For example:
    If column 71-72 is 05 add 5 lines after the 05.
    If column 71-72 is 09 add 9 lines....etc
    Has anyone ever tried this.
    thanks 8O
      Jun 25, 2006#2
      This is not easy because the macro language of UE has no support for variables or math expressions. But this special job can be done with a macro:
      Key HOME
      IfColNumGt 1
      Key HOME
      Loop 70
      Key RIGHT ARROW
      Key RIGHT ARROW
      Key RIGHT ARROW
      " ENDOFINSERTPOINT"
      Key Ctrl+LEFT ARROW
      Key LEFT ARROW
      Key LEFT ARROW
      OverStrikeMode
      IfCharIs "0"
      Key LEFT ARROW
      IfCharIs "0"
      IfCharIs "1"
      "0"
      IfCharIs "2"
      "1"
      IfCharIs "3"
      "2"
      IfCharIs "4"
      "3"
      IfCharIs "5"
      "4"
      IfCharIs "6"
      "5"
      IfCharIs "7"
      "6"
      IfCharIs "8"
      "7"
      IfCharIs "9"
      "8"
      "9"
      IfCharIs "1"
      "0"
      IfCharIs "2"
      "1"
      IfCharIs "3"
      "2"
      IfCharIs "4"
      "3"
      IfCharIs "5"
      "4"
      IfCharIs "6"
      "5"
      IfCharIs "7"
      "6"
      IfCharIs "8"
      "7"
      IfCharIs "9"
      "8"
      Key LEFT ARROW
      Key LEFT ARROW
      Key DEL
      Key DEL
      Find Select " ENDOFINSERTPOINT"
      Find "#"
      Replace All "^p"
      Find MatchCase " ENDOFINSERTPOINT"
      Replace ""
