Removing blank and comment lines...
    Feb 07, 2005#1
    I know this should be a simple macro... But for the life of me, I am not seeming to get how to write these macros. (of course, my programming skills have lain dormant for several years. *sigh*)
    Anyway, please help if you can.
    The commented lines start with # - if it weren't such a huge file, I'd manually do it - but it's 190+ pages of text.
    -Drake Steele :D
    206
      Feb 07, 2005#2
      You might have to run it two or three times to get them all (don't ask why)
      UnixReOn
      Find RegExp "^[#].*\p"
      Replace All ""
      Software For Metalworking
        Feb 07, 2005#3
        Comment lines starting with # in column 1 can be deleted with regular search expression %#*^p in UltraEdit style. Replace it with simply nothing.
        How to delete blank lines is described in the FAQs.
        Simply do the 2 Replace All commands and record it during execution to create the macro.
          Aug 31, 2005#4
          mrainey56,
          Thanks again. This time it worked. Little embarrased that I didn't turn on reg expressions. With the difference between Unix regexp and UEdit I guess I thought his would be on by default. When I checked the box it found and deleted "most" of them. Had to run it twice for only 10 lines of text with blank lines. I appreciate the reply.
