select -> copy / find whats it clipboard
    Feb 16, 2005#1
    Im trying to create a small Macro to select text in one open document, copy it into clipboard then switch to another open document and find the string that was copied to clipboard.
    My macro looks like that
    SelectLine
    NextDocument
    Find RegExp "^c"
    SelectLine
    somehow it doenst work. It just doesnt find the string even if the string is in the clipboard.. If I try to find the string that the macro has copied to the clipboard manualy.. i can find it.
    strings that i try to find are like this "000000149571-001-1", so I have to use selectline instead of selectword.
    any ideas how to make it work?
    regards
    Matthias
    46
      Feb 16, 2005#2
      Hi Akyno,
      You can't us RegExp with the ^c for clipboard replacement.
      So try this:
      SelectLine
      NextDocument
      Find "^c"
      SelectLine
      It's a limitation of the find command (it's explain in the documentation
      under regular expression).
      Regards from Geneva,
      Never forget: "Above the clouds, The sky is blue and the sun shine"
        Re: select -> copy / find whats it clipboard
        Feb 16, 2005#3
        hmm, tried it... still doesnt work... but its just a problem when I try to search for strings with - in them.. like this
        000000149521-001-1
        if I remove the - (0000001495210011) and use selectword instead of selectline, it works..
        no idea why...
        46
          Feb 16, 2005#4
          By me it seems to work just fine. Could you post some
          example of your faulty files.
          the macro I use is this:
          SelectLine
          NextDocument
          Find "^c"
          SelectLine
          PreviousDocument
          Regards,
          Alain
            Feb 16, 2005#5
            hmm.. what version are you using?
            I'm using 11.00
            46
              Feb 16, 2005#6
              I'm still in 10.20d+ (I wait a bit before upgrading).
