Act on selected text
    Feb 25, 2005#1
    I want to write a macro that acts on each line of the selected block of text.
    If I select three lines, I want the macro to add a few characters to the beginning of each line. Anybody willing to provide a little help on how to do this?
    Thanks in advance.
    JayPM
    206
      Feb 25, 2005#2
      This is the general idea. If you leave the (.) out of the Find string, it puts the "added" string in twice. I don't know why.
      UnixReOn
      Find RegExp "^(.)"
      Replace All SelectText "added\1"
      Software For Metalworking
        Feb 25, 2005#3
        Hmm.. so, I used your macro text and gave it a try.
        This is my macro:
        UnixReOn
        Find RegExp "^()"
        Replace All SelectText "//"
        (add the two slashes to the beginning of each line - I'm editing
        pascal source code, and I want to block comment lines out using UE)
        In a source file I selected 4 lines and invoked the macro
        and get a "Search String Not Found" error. Did I miss
        something??
        206
          Feb 25, 2005#4
          Try this:
          Macro > Edit Macro > Modify
          Check the "Continue If A Find With Replace Not Found" box
            Feb 25, 2005#5
            Also, you left the period out in the search string, and the \1 in the replace string.
              Feb 25, 2005#6
              Find RegExp "^(.)"
              Replace All SelectText "//\1"
              (and I made the switch) - but still nothing working.
              -Jay
              206
                Feb 25, 2005#7
                Somehow you turned off Unix mode.
                261
                  Feb 28, 2005#8
                  Do you realize that if you have syntax highlighting for Pascal, UE has a command to comment out (or uncomment) a block of text?
                  I added one line to my Wordfile.txt:
                  /L10"Pascal" Line Comment = // File Extensions = .psc
                  (I wasn't sure about the extension for Pascal!)
                  I made a test file with the .psc extension, then highlighted some lines, and did Edit | Comment Add.
                  There are probably full descriptions of Pascal that you can download to do all of the highlighting.
                  Dave
                  ASTTMan
                  I'm not a Texan, I just live here.
