Copy character from line above
13
    Mar 09, 2010#1
    In the Semware editor TSE there was a macro which I liked a great deal, which copied the character in the line above the cursor to the insert point.
    The SAL macro code - for the Mofi's of the world who understand SAL - goes like this:
    integer proc mCopyCharAbove()
    integer c,sv = Set(RemoveTrailingWhite,OFF)
    	PushPosition()			/* Save position */
    	c = iif(up(),CurrChar(),-1)	/* Try for char on line above */
    	PopPosition()			/* Back to where we were */
    	Set(RemoveTrailingWhite,sv)
    	return(c >= 0 and InsertText(Chr(c)))
    end mCopyCharAbove
    I have this assigned to Alt+Up in TSE like this:
    <Alt CursorUp>		mCopyCharAbove()
    It is a much-loved macro with a natural feeling key assignment, which I'd like to port into UE, but before I reinvent the wheel, is there already something for this in UE... and is this better in a macro or script?
    6,682583
      Mar 09, 2010#2
      I think nobody has yet coded that and published. With a macro you could hold Alt and CursorUp to run it repeated times while when coding it with a script you have to press the keys always again and again because the Cancel dialog can't be suppressed at the moment. But I think it is very difficult to code that with a macro because no support for variables which you surely need here for saving/restoring position in current line and check position in the line above.
      13
        Mar 09, 2010#3
        It hadn't occurred to me that typematic repeat wouldn't work in scripts. Can you invoke a script from a macro?
        6,682583
          Mar 10, 2010#4
          rstaveley wrote:Can you invoke a script from a macro?
          No, this is not possible.
          However, I think I get the task correct coded with a macro. Here is the macro code for copying it into the edit macro dialog. You should disable both macro properties for this macro.
          This macro worked for me with UE v16.00.0.1025 with configuration setting Allow positioning beyond line end (Configuration - Editor Display - Cursor/Caret) not enabled. The macro modifies the second line if the cursor is currently on the first line of the file. So don't execute the macro on the first line of a file.
          IfCharIs 13
          Key UP ARROW
          IfCharIs 13
          Key DOWN ARROW
          ExitMacro
          Key RIGHT ARROW
          Key DOWN ARROW
          ExitMacro
          IfCharIs 10
          Key UP ARROW
          IfCharIs 10
          Key DOWN ARROW
          ExitMacro
          Key RIGHT ARROW
          Key DOWN ARROW
          ExitMacro
          IfEof
          Key UP ARROW
          IfCharIs 13
          Key DOWN ARROW
          ExitMacro
          IfCharIs 10
          Key DOWN ARROW
          ExitMacro
          Key RIGHT ARROW
          Key DOWN ARROW
          ExitMacro
          Key UP ARROW
          IfCharIs 13
          Key DOWN ARROW
          ExitMacro
          IfCharIs 10
          Key DOWN ARROW
          ExitMacro
          Key RIGHT ARROW
          Key DOWN ARROW
          Key LEFT ARROW
          Here is the macro code as UEM (UltraEdit Macro) with comments for a better understanding. See Macro examples and reference for beginners and experts how to work with macro code in *.uem files.
          // Is the cursor at end of the current line terminated with
          // a carriage return - DOS files or not converted MAC files?
          IfCharIs 13
          // Move cursor up to line above. If the cursor is now at end of this
          // line, nothing can be copied and therefore the cursor is just moved
          // back to previous position.
             Key UP ARROW
             IfCharIs 13
                Key DOWN ARROW
                ExitMacro
          // Otherwise select the character, copy it to clipboard, move cursor
          // down to original line which is automatically placed again at end
          // of that line and simply paste there the copied character.
             Key RIGHT ARROW
             Key DOWN ARROW
             ExitMacro
          // a line feed - not converted UNIX files? Yes, same code as
          // above with the only difference to check for a line feed.
          IfCharIs 10
             Key UP ARROW
             IfCharIs 10
                Key DOWN ARROW
                ExitMacro
             Key RIGHT ARROW
             Key DOWN ARROW
             ExitMacro
          // Is the cursor at end of the file, use the same code as above with
          // the only difference to check additionally for a carriage return.
          IfEof
             Key UP ARROW
             IfCharIs 13
                Key DOWN ARROW
                ExitMacro
             IfCharIs 10
                Key DOWN ARROW
                ExitMacro
             Key RIGHT ARROW
             Key DOWN ARROW
             ExitMacro
          // The cursor is not at end of the current line or end of file.
          Key UP ARROW
          IfCharIs 13
             Key DOWN ARROW
             ExitMacro
          IfCharIs 10
             Key DOWN ARROW
             ExitMacro
          // Otherwise select the character, copy it to clipboard and move cursor
          // down to original line. Because of selecting the character in the line
          // above the cursor is now one position right the original position. So
          // the cursor must be set left before the copied character can be inserted.
          // This is the important difference in behavior in comparison to the code
          // above when cursor is at end of a line or end of the file.
          Key RIGHT ARROW
          Key DOWN ARROW
          Key LEFT ARROW
          13
            Mar 10, 2010#5
            Wow! You're a star, Mofi. I'm really pleased with this. :)
              Mar 10, 2010#6
              Mofi wrote:I think we will never see enhancements like support for variables for macros because scripts can be used for complex tasks...
              Do you reckon then that being able to suppress the cancel dialog would make scripts suitable for key commands like this in future, or are there other challenges too?
              6,682583
                Mar 10, 2010#7
                The Cancel dialog always displayed when running a script is the only problem for small scripts designed for repeated executions. Of course small macros are faster executed especially when the macro file containing all the small macros is loaded at startup of UltraEdit into memory. And script interpreting be the Javascript engine is surely also slower than the macro execution, think on reading the text file, check syntax, etc. not done for the compiled macros. But with the caching mechanisms of the operating systems and the fast hardware using also caching nowadays users can't see anymore any difference in speed when executing a small macro in comparison to a small script. So the difference in execution time for small scripts in comparison to small macros can be only measured with the fast processor, but not by a (slow) user.
                  Mar 19, 2010#8
                  I have once created a macro for this, which is considering the current editing mode (insert/override) and also handles tabs correctly. Here it is:
                  "CharFromAbove"
                  Inserts/overwrites one character from the line above.
                  Clipboard 9 is used.
                  IfSel
                  IfEof
                  Key END
                  Key RIGHT ARROW
                  Key LEFT ARROW
                  ExitMacro
                  Key LEFT ARROW
                  Key RIGHT ARROW
                  Key UP ARROW
                  IfCharIs 13
                  Key DOWN ARROW
                  ExitMacro
                  IfCharIs 10
                  Key DOWN ARROW
                  ExitMacro
                  Key RIGHT ARROW
                  Key LEFT ARROW
                  Key DOWN ARROW
                  Key LEFT ARROW
                  Find " "
                  Replace "^c"
                  In case you have the file in DOS format internally, then you can remove the "If CharIs 10" block.
                  Have a try.
