Macro to Change Numbers to Roman Numerals?
    Apr 18, 2010#1
    I'm trying to write a macro to change numbers to roman numerals. Ideally to search and find the word "Chapter" and replace the number [1-?] after it with "I, II, III, IV ..." So far this what I have:
    Main
    Clipboard 8
    Clipboard 7
    Clipboard 6
    Find Select MatchCase "Chapter "
    IfSel
    Key END
    Key LEFT ARROW
    Key LEFT ARROW
    Key LEFT ARROW
    Key LEFT ARROW
    IfCharIs "0123456789"
    Key RIGHT ARROW
    Clipboard 6
    PlayMacro 1 "RomanNums4"
    Key RIGHT ARROW
    Key RIGHT ARROW
    Clipboard 7
    PlayMacro 1 "RomanNums3"
    Key RIGHT ARROW
    Key RIGHT ARROW
    Clipboard 8
    PlayMacro 1 "RomanNums2"
    Key RIGHT ARROW
    Key RIGHT ARROW
    PlayMacro 1 "RomanNums1"
    Key END
    DeleteToStartofLine
    "Chapter "
    Clipboard 6
    Clipboard 7
    Clipboard 8
    Key DOWN ARROW
    IfEof
    Clipboard 8
    Clipboard 7
    Clipboard 6
    RomanNums1
    NewFile
    Key END
    Key LEFT ARROW
    OverStrikeMode
    IfCharIs "1"
    "I"
    IfCharIs "2"
    "II"
    IfCharIs "3"
    "III"
    IfCharIs "4"
    "IV"
    IfCharIs "5"
    "V"
    IfCharIs "6"
    "VI"
    IfCharIs "7"
    "VII"
    IfCharIs "8"
    "VIII"
    IfCharIs "9"
    "IX"
    IfCharIs "0"
    Key HOME
    Key END
    CloseFile NoSave
    RomanNums2
    NewFile
    Key END
    Key LEFT ARROW
    OverStrikeMode
    IfCharIs "1"
    "X"
    IfCharIs "2"
    "XX"
    IfCharIs "3"
    "XXX"
    IfCharIs "4"
    "XL"
    IfCharIs "5"
    "L"
    IfCharIs "6"
    "LX"
    IfCharIs "7"
    "LXX"
    IfCharIs "8"
    "LXXX"
    IfCharIs "9"
    "XC"
    IfCharIs "0"
    Key HOME
    Key END
    CloseFile NoSave
    RomanNums3
    NewFile
    Key END
    Key LEFT ARROW
    OverStrikeMode
    IfCharIs "1"
    "C"
    IfCharIs "2"
    "CC"
    IfCharIs "3"
    "CCC"
    IfCharIs "4"
    "CD"
    IfCharIs "5"
    "D"
    IfCharIs "6"
    "DC"
    IfCharIs "7"
    "DCC"
    IfCharIs "8"
    "DCCC"
    IfCharIs "9"
    "CM"
    IfCharIs "0"
    Key HOME
    Key END
    CloseFile NoSave
    RomanNums4
    NewFile
    Key END
    Key LEFT ARROW
    OverStrikeMode
    IfCharIs "1"
    "M"
    IfCharIs "2"
    "MM"
    IfCharIs "3"
    "MMM"
    IfCharIs "4"
    "(IV)"
    IfCharIs "5"
    "(V)"
    IfCharIs "6"
    "(VI)"
    IfCharIs "7"
    "(VII)"
    IfCharIs "8"
    "(VIII)"
    IfCharIs "9"
    "(IX)"
    IfCharIs "0"
    Key HOME
    Key END
    CloseFile NoSave
    I works, but still adds in some numbers and botches the last chapter. Any help would be greatly appreciated.
    Best regards,
    PoorPatriot
    262
      Apr 18, 2010#2
      I realize we are in the macros subforum and that you ask for help with your macro, but if UE scripts is an option for you ? (which UE version are you using) - scripts offer a more simplistic approach. Here is an example tested with UE 16.00.0.1036:
      // Setup some defaults for find function:
      // We use perl regex
      UltraEdit.perlReOn();
      // Start from top of document
      // Select chapternumbers. The regex uses positive lookbehind for the chapter
      // part which in previous UE versions has been reported as "shaky" but it is
      // tested with UE 16.00.0.1036.
      while (UltraEdit.activeDocument.findReplace.find("(?<=Chapter )[0-9]+")) {
      	// for each "hit" call romanize function with the "selection" chapter number
      	// and write back the roman numerals
      	UltraEdit.activeDocument.write(romanize(+UltraEdit.activeDocument.selection));
      // Use any of the "millions" of to_roman_numerals() functions on the net - just use Google.
      // This one is by " Ivan -DrSlump- Montes" from
      // http://blog.stevenlevithan.com/archives/javascript-roman-numeral-converter
      function romanize(num) {
        var lookup = {M:1000,CM:900,D:500,CD:400,C:100,XC:90,L:50,XL:40,X:10,IX:9,V:5,IV:4,I:1},
            roman = '',
            i;
        for ( i in lookup ) {
          while ( num >= lookup[i] ) {
            roman += i;
            num -= lookup[i];
        return roman;
      6,624550
        Apr 18, 2010#3
        My first suggestion would have been also to use a script. However, if you use an older version of UltraEdit not supporting scripts, here is a macro solution. I combined your 5 macros into a single one. The main mistake you have made is that you used IfEof as exit condition for the loop. But IfEof is only true when visible cursor is at end of file. When a find does not find anymore the searched string, the cursor position remains at current position. Therefore your main does not exit the loop after changing the last chapter number.
        Find MatchCase "Chapter "
        IfNotFound
        Key END
        Key LEFT ARROW
        Key LEFT ARROW
        Key LEFT ARROW
        Key LEFT ARROW
        IfCharIs "123"
        DeleteToStartofLine
        IfCharIs "1"
        Delete
        "M"
        IfCharIs "2"
        Delete
        "MM"
        Delete
        "MMM"
        Key RIGHT ARROW
        DeleteToStartofLine
        IfCharIs "123456789"
        IfCharIs "1"
        Delete
        "C"
        IfCharIs "2"
        Delete
        "CC"
        IfCharIs "3"
        Delete
        "CCC"
        IfCharIs "4"
        Delete
        "CD"
        IfCharIs "5"
        Delete
        "D"
        IfCharIs "6"
        Delete
        "DC"
        IfCharIs "7"
        Delete
        "DCC"
        IfCharIs "8"
        Delete
        "DCCC"
        Delete
        "CM"
        Delete
        IfCharIs "1"
        Delete
        "X"
        IfCharIs "2"
        Delete
        "XX"
        IfCharIs "3"
        Delete
        "XXX"
        IfCharIs "4"
        Delete
        "XL"
        IfCharIs "5"
        Delete
        "L"
        IfCharIs "6"
        Delete
        "LX"
        IfCharIs "7"
        Delete
        "LXX"
        IfCharIs "8"
        Delete
        "LXXX"
        Delete
        "XC"
        Delete
        IfCharIs "1"
        Delete
        "I"
        IfCharIs "2"
        Delete
        "II"
        IfCharIs "3"
        Delete
        "III"
        IfCharIs "4"
        Delete
        "IV"
        IfCharIs "5"
        Delete
        "V"
        IfCharIs "6"
        Delete
        "VI"
        IfCharIs "7"
        Delete
        "VII"
        IfCharIs "8"
        Delete
        "VIII"
        Delete
        "IX"
        Key RIGHT ARROW
        DeleteToStartofLine
        Key HOME
        "Chapter "
        For a better understanding of the macro code, once again the same code, but this time with indentations.
            IfNotFound
            Key END
            Key LEFT ARROW
            Key LEFT ARROW
            Key LEFT ARROW
            Key LEFT ARROW
            IfCharIs "123"
                DeleteToStartofLine
                IfCharIs "1"
                    Delete
                    "M"
                    IfCharIs "2"
                        Delete
                        "MM"
                        Delete
                        "MMM"
                Key RIGHT ARROW
                DeleteToStartofLine
                IfCharIs "1"
                    Delete
                    "C"
                    IfCharIs "2"
                        Delete
                        "CC"
                        IfCharIs "3"
                            Delete
                            "CCC"
                            IfCharIs "4"
                                Delete
                                "CD"
                                IfCharIs "5"
                                    Delete
                                    "D"
                                    IfCharIs "6"
                                        Delete
                                        "DC"
                                        IfCharIs "7"
                                            Delete
                                            "DCC"
                                            IfCharIs "8"
                                                Delete
                                                "DCCC"
                                                Delete
                                                "CM"
                Delete
                IfCharIs "1"
                    Delete
                    "X"
                    IfCharIs "2"
                        Delete
                        "XX"
                        IfCharIs "3"
                            Delete
                            "XXX"
                            IfCharIs "4"
                                Delete
                                "XL"
                                IfCharIs "5"
                                    Delete
                                    "L"
                                    IfCharIs "6"
                                        Delete
                                        "LX"
                                        IfCharIs "7"
                                            Delete
                                            "LXX"
                                            IfCharIs "8"
                                                Delete
                                                "LXXX"
                                                Delete
                                                "XC"
                Delete
                IfCharIs "1"
                    Delete
                    "I"
                    IfCharIs "2"
                        Delete
                        "II"
                        IfCharIs "3"
                            Delete
                            "III"
                            IfCharIs "4"
                                Delete
                                "IV"
                                IfCharIs "5"
                                    Delete
                                    "V"
                                    IfCharIs "6"
                                        Delete
                                        "VI"
                                        IfCharIs "7"
                                            Delete
                                            "VII"
                                            IfCharIs "8"
                                                Delete
                                                "VIII"
                                                Delete
                                                "IX"
                Key RIGHT ARROW
                DeleteToStartofLine
            Key HOME
            "Chapter "
