after calling "FTP open" automatically the last used site should be opened -- is this possible?
Carlos
Carlos
The webpage UltraEdit Latest Changes currently contains this information as well with an additional information about this feature at bottom.IDM wrote:v18.00.0
- Added support for automatically connecting to FTP account when opening FTP Open or Browse dialog
IDM wrote:To enable this, add "Auto Browse FTP=1" (without the quotes) on a new line in your uedit32.ini file under the [Settings] section. You must ensure that UltraEdit is closed when you modify and save the INI file, otherwise your changes will be overwritten. You can find the location of your INI file by going to Advanced - Configuration - Application Layout - Advanced. The location of the INI file is shown at the bottom of this dialog.
