How to fix saved password which must be re-entered on every connection establishment?
    Oct 19, 2015#1
    Hello, my problem is this:
    Every time I connect to my site on Altervista, UltraEdit requires the password. In the "Account Management" the password is entered and the option 'save password' is on.
    I don't want to type the password every time. How can I fix it?
    Thank you in advance :)
    6,688586
      Oct 19, 2015#2
      I suppose the saved password is not correct which is the reason why you have to re-enter it every time.
      You should see that in FTP log if you have enabled this log at Advanced - Configuration - FTP by checking Show FTP log in output window.
      Open File - FTP/Telnet - FTP Account Manager, select the appropriate account from the list and enter on tab General the correct password. Click on button Apply to save the updated/corrected password.
        Oct 20, 2015#3
        Thank you Mofi, it was as you said! :P
