Hi, anybody the same problem as i do:
ftp open of a guardian-file is no problem (except for the boring xcwd error: everytime a / is thrown in before the nodename).
ftp save always gives an error (STOR failed).
when you do a ftp save as than you can see that there is always an "/" in front of the filename. CHanging this "/" manually in a "." makes the ftp save work!
the filename convention on guardian is \node.$volume.subvolume.file
please advice.
regards,
willem
please advice.
regards,
willem
