Hi
I am trying new 11. version of ultraedit. First I have problem with sftp opening files (ue hang with cpu on 80-100%), so I deleted all my pre saved sftp configurations and recreate them. Opening files now working correctly until...
But now I have problem with saving files. When I open ultraedit, create a new file and save as it on sftp server as Edit1 it works perfectly. But then when I close dialog and try to open another file from same server ue hang with cpu on 80-100%.
The most worse problem is editing of files on sftp server. I opened some file on sftp, change there something and when I tried to save it, with ctrl+s it hangs with cpu 80-100%. I didn't realize how I can save edited file on sftp server because it still hang with spu on 80-100%.
I tried another server with FTP (not SFTP) and there it worked ok, without any problems.
I tried older 10.20 version (because I was curious how such things like sftp in such a known editor, could not works) of ultraedit and there it worked ok, without any problems. I was afraid that older version had same problems with sftp, but this is not that case. I am glad Its only new version bug and I understand that.
I tried version 11 on other computer and same problem persist.
I tried also root account and also other user account on sftp server and it still doesn't work.
Can someone help me?
Thank you for any answer.
