Can we customize the FTP dialog box?
    Apr 06, 2009#1
    Hi everyone,
    I'm using UE 14.20.1.1008 and something that really frustrates me is that if I resize a column in the FTP dialog box, that setting is gone when I open the FTP dialog again. I remember this being possible in previous version of UE. Resizing the entire dialog box seems to be saved, but not the individual columns. Can we set a permanent size for the columns? Also can we remove columns, for example the Type column?
    Thanks!
    2362
      Apr 06, 2009#2
      I have the same issue with the newly released UE 15.00.0.1033, so it hasn't been fixed in the new version either.
      If anyone has insight on a work-around here, I would love to hear it as well.
      “Don’t document the problem, fix it.” – Atli Björgvin Oddsson
        Apr 09, 2009#3
        i'm also
