List Command Filter Tutorial?
    May 05, 2009#1
    There is not much documentation on the 'List Command Filter' in the 'Ftp Account Manager' box.
    I get the impression it is like the Unix 'ls' command.
    I can get it to display all files that start with 'A' with the command "A*".
    What I really need is to exclude all files that start with a specific character.
    In my case, I need to exclude all files that start with the underscore character '_'.
    Any ideas or help?
    I am using Version 15.00.0.1033
      May 05, 2009#2
      First I recommend strongly to update to currently latest version because your version has many serious bugs.
      Second I never opened a file via FTP, but you can select on the Advanced tab in the FTP account manager dialog between Remote - Use LIST command and Local - Perl regular expressions. Select Perl and use [^_].+ as filter string. I can only hope that this works.
        May 07, 2009#3
        Thank you for the info. I will give it a try.
        Thanks again Dan
