Disable MLSD and Use LIST command instead
    Nov 25, 2009#1
    Is there any way to force Ultraedit to use LIST command instead of MLSD? It seems that the FTP server I'm using may have a bug and it always drops the last item when returning using MLSD. I used to use Ultraedit 14 and never had a problem. Just bought Ultraedit 15 and I can't get the last item in an FTP listing (both files and directories) now.
    Any help would be appreciated. Thanks!
    6,687587
      Nov 25, 2009#2
      I have never used the built-in FTP of UE. So I just opened the help of UltraEdit, entered on the Search tab FTP list and the first page found is about the FTP Account Manager. According to this help page there is the LIST Command Filter on the Server tab and the radio option Remote - Use LIST command on the Advanced tab in the FTP Account Manager dialog. So according to help it should be possible.
        Nov 25, 2009#3
        Thanks Mofi for the quick response. By default that options is selected in my configuration. It appears to be more related to filtering than the actual command that gets sent, unfortunately.
