Formatting XML
Formatting XML
PostApr 14, 2005#1
Can UltraEdit format an XML document?
For example: <TAG1><SUB>HELLO</SUB></TAG1> would become
<TAG1>
  <SUB>HELLO</SUB>
</TAG1>
I am the registered user of UltraEdit 9 and was wondering if there is a way to do above.
Thanks in advance.
PostApr 15, 2005#2
You can use Tidy for formatting. I have following Perl script assigned to tools, but guess you can also use bat or wsh :
Command line: perl -w C:\bin\xmlformat.pl "%f"
C:\bin\xmlformat.pl
#!perl -w
# Name: xmlformat.pl
# Use tidy to change input file and make bak
# Usage: xmlformat.pl xmlfile.xml
use strict;
use File::Copy;
die "No args...\n"
 unless 0==$#ARGV;
my $xmlfile = shift;
die "Could not copy $xmlfile. $!\n"
 unless copy($xmlfile, "$xmlfile.bak");
my @args = ('C:\\bin\\tidy.exe', '-m', '-xml', '-q', '-i', $xmlfile);
system(@args) == 0 or die "system @args failed: $?"
Regards,
vel
PostAug 01, 2005#3
vel, thank you for the hint to Tidy. As a non Perl programmer I'm now using an UltraEdit Tool configuration with the command line
cmd /c if /I "%E"==".XML" (E:\schlereth\tools\tidy\tidy-050522-exe\tidy.exe -m -xml -i "%F") else (echo NO XML File)
and
Command Output (DOS Commands) to List Box, Capture Output.
PostAug 29, 2011#4
UltraEdit v17 does it (maybe previous releases too):
  1. Select the desired text,
  2. in the main menu, select Paragraph Formatting + ReIndent Selection, the result is here as the result of an XML beautifuller output
Regards
Bonjour,
UltraEdit v17 le fait (peut être d'autres versions précédentes également):
  1. Sélectionner le texte désiré,
  2. dans le menu principal, sélectionner Formatage du paragraphe + Indenter de nouveau la sélection, le résultat est là, identique à la sortie d'un embellisseur XML
Cordialement
901
PostSep 01, 2011#5
Wow, you really dug up an old post to respond to. The easiest way to handle the original post in the current version of UltraEdit is with the drop-down menu option:
Format -> XML Convert to CR/LFs
PostNov 11, 2020#6
bulgrien, 9 years later your post helped me out.  Thanks!  --Joe
PostNov 12, 2020#7
The command XML Convert to CR/LFs in menu Format was introduced with UltraEdit for Windows v11.20 and UEStudio v5.10 for files syntax highlighted as XML files. This command became available for all files, regardless of file extension and syntax highlighting, with UltraEdit for Windows v17.10 and UEStudio v11.10.
The command XML Convert to CR/LFs in traditional menu Format was replaced by Reformat XML in submenu XML with UltraEdit for Windows v27.00 and UEStudio v20.00 which additionally introduced the command Compress XML. The commands are in menu Coding in submenu XML on using contemporary menus. In ribbon mode the commands are listed in popup menu opened on clicking on ribbon tab Coding in group Formatting on down arrow of item XML.
