More AHK Goodness - show list of project files
23
PostFeb 10, 2012#1
Not sure if I just couldn't find a hotkey in the configuration or what, but I wanted to press Ctrl+L and see the searchable list of project files.
In AutoHotkey ( https://www.autohotkey.com ):
#IfWinActive, .*UltraEdit$
    ^l::
 PostMessage, 0x111, 33195, 0, , A
 return
#IfWinActive
PostFeb 12, 2012#2
I'm not sure which window you mean.
UltraEdit has the command ProjectFilesSettings in the Key Mapping configuration dialog for assigning a hotkey to this command opening the project settings dialog where also the project files are listed.
UEStudio has additionally the command IntellitipFileList in the Key Mapping configuration dialog for assigning a hotkey to the command which opens a small quick window listing the project files as the command File List in the IntelliTip toolbar opens.
23
PostFeb 12, 2012#3
In the File View, Project tab you can right-click the project name and choose "list files in project," which pops a search/listview for you to narrow down files.
I don't like having to use the mouse, so I used that AHK script to map it to the keyboard.
Were you implying such easy access was only available in the UEStudio product? Because I code using UltraEdit and would hate to think there are little productivity enhancements in one product that could be carried back to another.
PostFeb 13, 2012#4
Ah, now it is clear which window you mean. Yes, the command to open this window with the list of project files is available only in the context sensitive popup menu of the Project tab of the File Tree View (UE) respectively Workspace Manager (UES).
The IntelliTips feature is not available in UltraEdit at all. The command IntelliTip file list lists also file names which are part of the project but not listed in the project settings dialog. Those files are included mainly with #include <includefile.h> and only the IntelliTips feature knows where such include files are located. Those files can be found in the standard library folder(s) of the used compiler. And UEStudio can find them automatically only if using a project template of UEStudio containing the specification of the standard library include paths. UltraEdit projects do not contain any compiler specific settings.
44
PostFeb 15, 2012#5
Sweet! UltraEdit and AHK are two of my favourite all purpose "get things done tools" - thanks for this!
Rob
23
PostFeb 15, 2012#6
Mine too. I have infinity of scripts. Ahk has a very lively irc channel #ahk on irc.freenode.com
I use a lot of scripts also outside of UE, which is why I generally don't write UE macros. Plus ahk lets you make quick and dirty GUIs. Nudge nudge UltraEdit scripting engine person ;)
5
PostJun 21, 2013#7
Hi, I'm also a fan of both UE and ahk. I see you used #ifWinExist here to test if the active window is UE.
Using the ahk spy, it seems that UE does not its own special ahkClass value to use in e.g.
#IfWinActive ahk_class ....
If one wants to request this, which of IDM vs. Authotkey do you think one should contact?
23
PostOct 29, 2014#8
Make sure
settitlematchmode, regex
is set at the top, and then use this:
#IfWinActive,ahk_class Afx:00400000.*
It does a partial match on the part of the UE class that doesn't change.
I've got a much larger script that's kind of muddled, but I use the following method for the SendMessage constants:
;	# Run app function (sendmessage)
SendApp(iConstant) {
	SendMessage, 0x111, iConstant, 0,, A
I use the following constants. Note that some are positional (I've used my own tool names for tools 1-5, but those correspond to the order of your tools)
[Constants]
iConfiguration          = 32839
iCodeCommentAdd         = 33036
iCodeCommentRemove      = 33037
iCodeCommentSelected    = 41055
iCodeUnCommentSelected  = 41056
iColumn_ConvertToFixed  = 33108
iColumn_Number          = 32831
iEditDeleteActiveLine   = 32862
iEditBookmarkLine       = 32794
iSearchFindInFiles      = 32833
iFileName_Active_Copy   = 33038
iFileShowAs_AHK         = 34301
iFileShowAs_ASP         = 34316
iFileShowAs_CS          = 34302
iFileShowAs_CSS         = 34303
iFileShowAs_DotNet      = 34304
iFileShowAs_INI         = 34305
iFileShowAs_Javascript  = 34306
iFileShowAs_JSON        = 34307
iFileShowAs_MySQL       = 34308
iFileShowAs_None        = 34319
iFileShowAs_Perl        = 34309
iFileShowAs_PHP         = 34310
iFileShowAs_Python      = 34311
iFileShowAs_Raider      = 34312
iFileShowAs_SQL         = 34313
iFileShowAs_TTUHSC      = 34314
iFileShowAs_UWC         = 34315
iFileShowAs_VB          = 34317
iFileShowAs_XML         = 34318
iFileSort               = 32871
iFileSaveAll            = 32815
iProjectFile_Edit       = 65512
iProjectFile_Refresh    = 32781
iProjectFile_Search     = 33195
iProjectTool_SQLCommand = 33094
iTemplates_Rename       = 11119
iThemeOrganizer         = 13000
iTools_1                = 32785
iTools_AHK_Run          = 32875
iTools_UWC_SQL          = 33092
iTools_Raider_SQL       = 33093
iTools_2                = 32786
iTools_3                = 32877
iTools_4                = 32878
iTools_5                = 32879
iTools_6                = 32880
iTools_7                = 32881
iTools_OpenActive       = 32881
iWindow_Close           = 65289
iView_XML               = 3298
iFormat_XMLCRLF         = 33332
iFileName_Active        = 33038
iFileSort               = 32871
iTools_1                = 32785
iTools_2                = 32786
iTools_3                = 32877
iTools_4                = 32878
iTools_5                = 32879
iTools_6                = 32880
iTools_7                = 32881
iView_XML               = 3298
I do some custom coding now and again for baby money, so if you need something specific, let me know. I'm happy to help with the general things for free when I have time.
PostAug 28, 2018#9
Hello!
How were you able to determine value of 33195 for that specific action "List files in project..."?
I would like to have another hotkey that would "Select Active File", but I don't know what would be the value to pass into the PostMessage.
PostOct 27, 2018#10
Hi Guidam,
Tools like Resource Hacker can be used to find out the identifier number of a resource like a popup menu item.
But the context menu of the project in tab Project of File View is something special because it is dynamically constructed from popup menu and string resources. Most of these resources are in ueres.dll, but some are in executable of UltraEdit, i.e. uedit32.exe or uedit64.exe. The last menu item Select active file is a string from a string table resource in UltraEdit executable while most other items like List files in project... are from a popup menu resource in ueres.dll, whereby the popup menu resource contains the string Open File in Project... with identifier number 33195 instead of List files in project....
The string Select active file has the resource identifier number 61465. I don't know if this is also the identifier number used for the dynamic popup menu item, but I think so as it would explain the wrong prompt text in status bar for this menu item. Try it out if this number works in your AutoHotkey script.
PostNov 19, 2018#11
Thank you Mofi
This works as expected.
I will take a closer look to Resource Hacker later, but for now I'm really glad with your complete answer
