How to set up Perl run tool?
7
PostDec 30, 2022#1
I've searched the forums but didn't find an answer.
UltraEdit 2022.1.0.124 64-bit
Windows 10 Home 21H2
I want to set up a tool entry for starting an edited Perl script from UltraEdit. I've read the help files. Because I've bought/installed UE in German, I only can give German dialogs.
Navigation path is: Extras >> Benutzerwerkzeuge >> Werkzeuge konfigurieren (Advanced >> User tools >> Configure tools)
I have input:
Tab Befehl (Command)
Perl Run '1'
d:\sperl\perl\bin\perl.exe "%f"
"%p"
Tab Optionen (Options)
(*) DOS-Programm
[X] Aktive Datei erst speichern
Tab Ausgabe (Output)
(*) Ausgabe in Listenfeld
[X] Ausgabe aufzeichnen
(*) Nicht ersetzen
(*) ANSI
If I start with Extras >> Benutzerwerkzeuge >> Perl Run '1',  I get the message:
Fehler beim Erzeugen des Prozesses
Der Verzeichnisname ist ungültig
Ausgabefenster:
d:\sperl\perl\bin\perl.exe "D:\Dokumente\Prog\Perl\sum-which-values.pl" ...
May you help please or give a hint?
Thanks in advance, Thomas
PostDec 31, 2022#2
The working directory must be configured with just %p without the double quotes. Everything else looks correct.
Background information: There is called the Windows kernel library function CreateProcess with function parameter lpCurrentDirectory being a long pointer to the string with the directory path of the directory to use as current directory for the started process. The character " is not valid in a directory path as explained by Microsoft in the documentation about Naming Files, Paths, and Namespaces. UltraEdit does not remove double quotes added by the user around the working directory path. CreateProcess does also not remove the double quotes. That is also the reason why Start in directory path in a shortcut file with file extension .lnk or a scheduled task must be always configured without surrounding double quotes.
7
PostDec 31, 2022#3
Thanks, does work fine.
