I work on MacOs (Sonoma 14.4), M3-Machine.. I try to run a script that should be executed on the Mac Terminal. So I got to Tools->Scripting-> Scripts .. when i m there, i chose "add" a scripts, but i see all scripts "disabled" (so the .sh file is not recognized as script), so I chose "Show Options" and i chose "all files" (as file type)... then i can pick my script file...then its added and I try to run it .. (it is a simple shell script in macOs to be run in the terminal) .. nothing happens, no terminal is opened. So i go to "tool configuration" and fill it accordingly (using absolute paths to be safe) there is even a line titled "command line"... so it should open the terminal, but does not help either
PS: I am using the UE version is 2023.0.0.22 ... any idea what could be the issue?
