Send all open file names to tool
6
    Jan 20, 2006#1
    I know how to send the current file name/path to an advanced tool, but is there a way of sending the file name/path of ALL open files?
    6,682583
      Jan 23, 2006#2
      No, not directly! Does your tool support a list file?
      Many tools like packers or UltraEdit or UEStudio supports a list file, which contains per line the full path and name of a file. It's possible to generate such a list file with the names of all open files with a macro and then run the tool from within the macro with the list file.
      If your tool does not support a list file, it is possible to use a macro to generate a "file1 file2 file3 file4" string (all files with full path), select this string and run the tool. The tool must have specified as parameter %sel%.
      Note: The second method has 1 disadvantage. The number of characters on a command line is limited by Windows (1024 characters, I think). So it will fail if you have many files with long path/name open.
      Tell us if your tool supports a list file or if method 2 must be used. Also let us know, which string can be found in all open files at least once but not too often because a Find In Files must be used to get the file names of all open files - see Return just list of files.
      6
        Jan 24, 2006#3
        I can re-program the tool to read a list file if I need to. It takes a basic command line variable of a file name now, but it won't be hard to parse the file names from a list file instead.
        Basically what the tool does is merge a number of NCF files for a specific part number to be sent to a another program (which I also wrote), that will use RS232 to transfer the merged files to a CNC machine.
        The NCF files will generally have the same basic file name, i.e.
        Dir\680-006195-1 REV 1-1.NCF
        Dir\680-006195-1 REV 1-2.NCF
        Dir\680-006195-1 REV 1-3.NCF
        Although at times they will be different, i.e.
        Different Dir\D896982-1 REV 1-1.NCF
        Different Dir\D896982-1 REV 1-2.NCF
        They will all contain the same basic info at the beginning of each file, with the 3rd line of every file containing the file's name, i.e.
        O0001
        (680-006195-1 REV 1-1.NCF)
        (JAN 23, 2006 12:25)
        <snip>
        O0002
        (680-006195-1 REV 1-2.NCF)
        <snip>
        O0003
        (680-006195-1 REV 1-3.NCF)
        <snip>
        The group of file names that I will be merging will almost always be different every time I use the tool.
        Thanks for the help.
        6,682583
          Jan 24, 2006#4
          The first macro will generate a list file with the full names of all open files which contain a line starting with a (, followed by any characters and has the string .NCF) (line 3 of your NCF files). It should be found only once in every open file. If there are more occurences of this string found in a file, the Sort command will remove duplicates.
          Modify the path and name of the list file at the end of the macro to your needs and add the macro command to run your tool at the end of the macro.
          The Loop is a workaround for a bug I found in v11.20a. UltraEdit continues the macro execution after FindInFiles before the log file with the search results is generated and has the focus. The loop searches through the open files for the log file with the search results.
          FindInFiles RegExp Log OpenFiles "" "" "%(*.NCF)"
          Find RegExp Up "%Search complete, found *^p"
          Delete
          NextWindow
          Find "----------------------------------------^p"
          Replace All ""
          Find RegExp "%Find *^p"
          Replace All ""
          Find RegExp "%Found *^p"
          Replace All ""
          Find RegExp "/[0-9]+:*$"
          Replace All ""
          SortAsc IgnoreCase RemoveDup 1 -1 0 0 0 0 0 0
          SaveAs "F:\Temp\NCF_List.txt"
          UnixReOn
          Here is a second macro which generates a single line with full names of all open files (with surrounding "") and selects it, so you can run your tool with all open files specified on the command line and the tool parameter %sel%.
          Delete
          NextWindow
          Replace All ""
          Replace All ""
          Replace All ""
          Replace All ""
          Find RegExp "%^(*^)^p"
          Replace All ""^1" "
          Key END
          Key LEFT ARROW
          UnixReOn
          You have to enable the macro property Continue if a Find with Replace not found for both macros.
          6
            Jan 26, 2006#5
            The second macro will work great with a small bit of tweaking with the %sel% function. I don't think I'll need to adjust the program's command line interpreter either.
            Thanks Much!
              Jan 27, 2006#6
              Worked out well for the most part. The only thing that's bad (and it's something I could live with if I had to) is that it seems to be stuck in a do-loop or is waiting until I exit the program called in the tool. (Shows the cancel dialog until exiting)
              Thanks again!
              6,682583
                Jan 27, 2006#7
                Rekd wrote:... that it seems to be stuck in a do-loop or is waiting until I exit the program called in the tool. (Shows the cancel dialog until exiting)
                Yes, that's normal. The tools are designed for a fast and short execution and then UltraEdit get's back the focus with or without the captured output from the tool. The macro waits for the tool exit before it continues to give the users the capability to modify the result of the tool - paste clipboard content from the tool or opens a file generated by the tool. It's also possible that the output of the tool is captured and replaces the current selection - see Advanced options in the tool configuration.
                So you have to press the Cancel button or the ESC key when your tool is started or you remove the tool macro command from the macro and always run first the macro (with a hotkey) and then your tool (also with a hotkey).
                6
                  Jan 28, 2006#8
                  Makes good sense. I had a feeling it was along those lines. Perhaps an idea for future versions would be a way of doing some sort of 'process and procede' function. :wink:
                  The more I use it, the more I am realizing just how powerful these macros are. It's more like a scripting language than a macro function.
                    Jan 30, 2006#9
                    Do you know what command is sent back to UE after the tool exits? Perhaps I could code that into the tool. :idea:
                    6,682583
                      Jan 30, 2006#10
                      No, I don't know. I'm not a Windows programmer so I don't know how this is handled by Windows. Ask IDM support by email. The developers of IDM can tell you surely how the exit of the tool is detected by UltraEdit.
