Launch a macro or windows program from menu or button
35
    May 29, 2006#1
    Hi-
    Is there a way for me to run a specific macro or a specific windows program via a custom menu selection and a custom (toolbar) button?
    With Regards-
    Sam
      May 30, 2006#2
      Windows programs - yes, if you set up a user tool for every program. Macros - no, use the macro list view.
      35
        May 31, 2006#3
        Hi Mofi-
        Thanks for your post.
        I used Tool Configuration and inserted a user tool:
        For Command Line, I browsed to the vbs script that I want to run. I then checked Windows Program.
        Launching it results in "Error creating process193".
        I found another post where you had advised adding %F which I tried - but with same result.
        Any idea what I am doing wrong?
        With Regards-
        Sam
          May 31, 2006#4
          A vbs file is not a program, it is only a script file and needs an interpreter for execution. For Windows XP it is WScript.exe. The correct command line to execute your vbs file would be
          C:\Windows\System32\WScript.exe "name of your script file with path"
          or if you want to run the vbs file currently open in UltraEdit
          C:\Windows\System32\WScript.exe "%f"
          And wscript.exe is a Windows program. So don't forget to select the "Windows Program" option in the tool configuration dialog.
          35
            Jun 01, 2006#5
            Thanks Mofi - I appreciate your help.
            With Regards-
            Sam
