Turbo C++ 3 + UE32
Turbo C++ 3 + UE32
    Oct 03, 2006#1
    How can I connect tc++3 compiler to ue32 12.10?
    I inserted in COMMAND LINE: C:\TC\BIN\TCC.EXE %f
    WORKING DIRECTORY: %p
    but unsuccessfully...
    :roll:
    please help
      Nov 07, 2006#2
      Read the manual of your compiler. I guess, you will need a makefile because you not only want to compile the C/C++ code to ASM code, you also want to assemble it and link it to an EXE. And the compiler must also know where the default libraries are for compilation.
