FTP Save dialog and Custom User Tools
    Feb 24, 2010#1
    Hi Guys,
    Back in UltraEdit 12, I had a Custom User Tool that compiled FTP files in a remote host after saving them. It consisted of call to the compiler through the external tool plink, with the "Save Active File" option in the UE Tool options dialog.
    After updating to UE 15.20, the FTP save progress dialog became a non modal window and sometimes the compilation gets executed before the file is actually updated on the remote host. What I end up having is an outdated binary file or a compilation error.
    Do you know any way for a Custom tool to wait for the save operation to finish?
    Thanks in advance.
    6,682583
      Mar 06, 2010#2
      You should report this problem by email to IDM support. UltraEdit should wait with the user tool execution until the file saving process is finished, even when the file is saved on a remote server using FTP (and needs some seconds to finish the file saving process).
