I created a project of related files. I've been working on the project for several days. I realized that some code I wrote for one program would be useful as a standard library routine so I created a new file tab in UltraEdit and copied the code into it. After adding in the necessary lines to make it a callable external routine, I named and saved the file locally (the project files are opened via FTP from a remote server). I did not add this new file to my project.
If I open files using the recent file list or by the Open command on the File menu, only the file or files I select open. However, whenever I load project precip_presav the other file is opened as well and since it is local it is always the first tab. As you can see in the attached image, the six files that are members of my project are opened. The extra file, new_set_6hr_val.pro.txt has opened as well. This time it and my project opened full sized but sometimes they open as cascaded windows which is also unwanted.
I do not have the Advanced -> Configuration -> File Handling -> Load -> Reload files previously open on startup box checked.
I am not a regular user of projects so I do not know if this behavior is normal or a bug, but I lean towards the latter.
UltraEdit version 21.20.0.1004 (due to IT manning issues, no upgrades will be installed until the next major version is available)
