Project tab stop setting
    Jun 13, 2006#1
    Is there a way to set the Tab Stop Value for a project? I have only found the one overall/general tab stop setting in the Advanced Configuration dialog.
    I work with some guys who prefer 4 char tab stops and others who prefer 3 chars. It would be nice if the tab stop setting could be made on a project basis and would change automatically as you load each project.
      Jun 13, 2006#2
      No, this is not possible. Tab stop settings can be only specified on a file extension basis but not project specific. This is one reason why I use also special INI files for some projects. There are other settings which are in my usage also project specific but cannot be saved in the project file.
