Compare permissions of folders on different servers
PostMay 25, 2011#1
Hi, I was wondering how I can compare two folders.
I want to compare the permissions of two folders on two different servers like so:
Server A >C:\inetpub
*compare to*
Server B >C:\inetpub
and see the differences.
Is this possible?
PostMay 25, 2011#2
UltraCompare compares files and folders by file date, file size, or file content, but not by file/folder permissions.
There is the SysInternals (Microsoft) tool AccessEnum to get a list of all files and subfolders of a folder with effective permissions. This list can be saved as CSV file. Doing that on both computers makes it possible for you to compare the permissions with UltraCompare by comparing the 2 CSV files. But AccessEnum supports also a built-in compare with a previously saved CSV file.
PostMay 26, 2011#3
Thank you so much Mofi, I managed to extract the information with AccessEnum and then compare the two files with UltraCompare.
Thank you so much serious, I was looking for this for a long time now.
